currently replacing exhaust valves on ser #59777 1941 9-n, i have question regarding the current replacement straight stem non rotating valves. the replacement type avail has no shoulder under the valve head for the valve guide to butt against(the orig style both straight and mushroom style used this shoulder for the valve guide and spring assembly to bear assembled spring pressure) therefore you cant bench assemble these then slide them back thru the lifter bore and reinstall the horseshoe valve guide retainer as was done originally,you have to piece these into place. does this style of valve rely on the horseshoe retainer to function and hold valve spring pressure the same as the valve shoulder on both the original style straight and mushroom style valves?
