Picked up 5 gallons of Extreme Pure Flow Tractor Hydraulic Transmission Fluid from Tractor Supply. It states it's compatible with all tractor transmission / hydraulic fluids. It does reference Ford and New Holland tractors. For them it lists as ESN-M2C 134B,C. I need to change the transmission / hydraulic fluid in my 2N as I don't think it has ever been changes and I've had the tractor myself for about 27 years. Can I use this fluid? Might add I live in Mid-Michigan about 45 miles north of Saginaw. This is just an old work tractor. Not used much, also has low compression on cylinder #4 with blow by as my oil breahter does smoke a bit.
Thanks,
Bill
Thanks,
Bill
