F-150 still a problem
S.Crum
I'm still having performance problems with my 89' F-150 with the 5.0 FI engine and 5 speed stick. I've narrowed the problem down to power production below 1,500 RPM. Starting out from a stop, lugging below 1,500 etc. Seems like as long as I keep the RPM above 1,500 everything is fine, not efficent but fine. Starting out from a stop sign especially into traffic requires a little advance planning and fuel mileage ins't the best. After starting out, as the engine winds up it dogs until 1,500 then takes off with all the power it needs. This has been completely tuned up including new filters and a new distributor and module. No appreciable change from this.
i had one doing that and it was the temp sensor that told the computer how hot/cold the engine was.Any codes from computer? I know some of the 80's stuff didnt give a code for this
Timing ? make sure to unplug spout connector when setting timing . Also index the mark on the damper to make sure it is at true TDC . Seen few of them that had slipped .
Hello s.crum,
Have you checked the ERG valve?
If it has a small leak, the engine would be a little sluggish at low R.P.M."s, the overcome the small leak , and run fine at higher R.P.M."s.
Guido.
s.crum,
How about the Catalitic Converter could it be partially clogged????? Just a thought.
Later,
John A.
I hear that on occaision "plugged Cat.converter". Out of curiosity how often do they fail?? is there a certain mileage, or use or type of Cat. converter that is known for failure ??? I heard to pull an Oxygen sensor and put a pressure guage on and if it makes more than 3 Psi. out of that hole its bad...
Depends in the vehicle. One that gets driven several miles at every start up will last for 250,000 miles. One that gets driven short trips and doesn't warm up to operating temp for a very long time if at all could be ruined in 50K.
Are you guys thinking maybe carbon or something on the pintle or in the seat causing a vacuum leak? This valve was new last year.
Sounds like your plenum gasket this leaking. They develope a vacuum on the right side or between port 1 and 2 on the intake internally.
The plenum gasket is the gasket between your upper intake and your lower intake manifold.
Beware of the bolt in the middle on the right it is a torx and the others are regular bolts
I agree with the catalytic converter being plugged.Might be the EGR valve,or both.My car had the catalytic converter plugged so bad it wouldnt run hardly at all and the check engine light wouldnt come on.Might have been burnt out or disabled too.I bought it at a car lot so dont know.Replaced catalytic converter and fixed it.
An 89 would just about have to be on life support to throw a check engine light. It sounds like a timing or vaccume issue. If the timing cover shows any sign's of ever being removed to replace the chain I would suspect the cam is a tooth off.
I would recheck every vaccume line for crack's - especially where they plug in. I would replace the plenium gaskets as they are cheap and fairly easy. Then I would pull no 1 plug, top of compression stroke & ckeck the balancer mark to be sure it hasn't slipped on the rubber ring. Then I would recheck the timing. That get's the basic's out of the way.
If she starts & runs rough when cold I would replace the TPI. It rarely shows up bad on a scanner even when it is. You can test it with an ohm meter as it's nothing more than a variable resistor. (Steady climb and no dead spots.)
Check engine light was on for several years on my '93 what a piece. State Farm paid my for it not a bad day.
