F-20 Belly Pump Hydraulics
Pace F20s
Is the belly pump commonly mounted in F-20's the same pump as the Lift All belly pumps in H's and M's?
I'm needing a service manual and want to be sure I get the correct one.
Thanks, Roland
From what I have seen the pump that is used on an F-20 is the same as the one for the M except that it is mounted diferently.
The Liftall pump on the F20 mounts on an adapter plate which is bolted to the front of the transmission. Pump has the same drive setup as the M except that it's driven from the PTO shaft.
