F12 sleeve diameter
F-12 guy
Does anyone know the OD and ID of a farmall F12 sleeve? I"m needing to get a puck made for my sleeve puller. Thanks Josh in Nc
The inner diameter is 3 inches I believe, same as the farmall A/B/C sleeve. Just add a little to that and you should be good. Tractordata.com should have the measurements if you want to double check.
Sine they're wet sleeves you can drive them out using a piece of oak and a big hammer. I did this on a Farmall A in 1975 that was stuck. Hal
PS: I reused the rods on the new pistons that came with the sleeve kit. Hal
You just need a puck bigger than the bore. The sleeves stick down into the lower end quite a bit. Once you move them up to where your puck will touch the block they will come right out without the puller
