f150 door locks
Did they quit all at once, or not work to begin with? There should be a fuse. If you live in the boonies, dust can get in the doors and mess with the electrical connections (check your grounds real good).
Dave
Test for power at the door switches.Should have 12v in natural position at one terminal and 12v when operating the switch at another.I've found problems like door to body pass-thru wires broken and bad door switches and lock actuators.
Check fuses first.
I had a blazer ( I know that's a Chevy) but the passenger side switch was broken and the drivers side would not work the locks until I put a new switch in
I just had all the window switches in my 2005 f150 replaced and a guy I work with just had his drivers side door rear window switches replaced. I think ford just plain has garbage switches.
Kevin
