F40 steering wheel
use a top quality penetrating oil
etc: http://www.kanolabs.com/
give it 4/5 days to work
if you want to save steering wheel may be more problem, as you do not want to use heat if you do not have too. heat will run down shaft and could ruin top seal in steering gearbox.
attaching puller to steering wheel spokes is the trick,
may have to make two plates that bolt together under steering wheel with hole in center for steering shaft.
Then attach puller legs to plate.
Note if you have not used a wheel puller much: as soon as it gets tight tap steering wheel around shaft area. Taping the part to be removed is very important, many times a few taps while under pressure the part will just pop apart.
Note: when reinstalling steering wheel use anti seize material on shaft and you will be able to get steering wheel off in future with ease.
Good luck and be careful,
