Farm all 95A
za766
I have a new to me 2021 Case IH Farmall 95A with 170 hours. I purchased this winter as a hay and cattle farm tractor with cab and MFWD. Last week I was loading hay bales and had it idling for a bit after done setting in my shop. After shutting off I noticed a leak under the front end before closing up and going to the house. Opened the hood and saw diesel fuel in the casting at the front and was leaking out the bottom. Noticed some rubber hoses that appeared to go to what I thought to be a cooler. Went through the operators manual but had nothing to tell me what it is. Want to buy a service manual but haven’t found one yet. Can anyone point me to where the leak may be coming from up in front of the engine?Thanks in advance.
Have a cx90 which is close to same. Had same problem. Mine has a fuel cooler in front of radiator. Just a simple fix of new rubber fuel lines. Got them at napa.
Thanks wh!! I’m sure you are dead right on it being the hoses as they appear weather checked from what I could see. They have single ear cinch clamps on the hose to pipe that may be the leak. Thanks again for your quick response.
