Farmall 130 hydraulic pump
Big Boar
The hydraulic pump on my Farmall 130 has a crack and leaks. A new pump is around $500. Anyone have a suggestion as to where I can get a used pump casing?
As mentioned in another post, JP Tractor or Burch Tractor in Burlington NC will have used pumps.
Charlie Burgh (harmony,pa used) . Bates Corp (new) ,
on C two types Thomson,and pashel, one has few parts available .
I ve gone through them to remove wear. Cost time and money is about same as price of new one.
Do not get used one with oil seal the shaft is worn at sealing area of shaft , have build it up and machine shaft to seal it ,not worthless, but way more costly than new . Oil buy the o ring type, get oversized o ring from McMaster Carr. I what think.
Do you need the pump? Bolts on the motor near the front? Or the touch control unit under the gas tank?? I have both for sale off a super A , cheap in Sylacauga, AL. Can ship
