mmoorefield
I recently bought a 1972 farmall 140 that had be sitting since about 2005. The engine was stuck when I got it. I managed to get it broke loose everything looked good but the bottom side of the head for the #1 piston so I pulled it and replaced the rings. All four bores looked fine and so did the other three pistons so I didn't pull them. After I got it back together and running I thought I had a fuel issue, the tractor would run about 60 seconds and shut off. After it shut off the starter wouldn't turn the engine over immediately but if you wait another seconds it would turn over and start just fine and repeat the process shutting off again. I thought it may have been out of time when the starter wouldn't tirn it over.tried a different carb and it did the same thing. Finally I could tell something was getting tight. So I started pulling spark plugs out and running it. When I made it to the #3 cylinder it stayed running and runs fine as long as you want. I'm assuming the rings are stuck and swelling with heat. Has anyone had experience with this? I don't really want pull the engine back apart until winter since it's garden season. Any help will be appreciated.
Matt
Matt
