Farmall 140
Anonymous-0
Message for Hugh McKay,
Can I replace the gear train in the 140 with a gear train out of a Super A or B and slow down the 140?
Thanks,
Robert Berry
If you want to go real slow, you need a Hydro-creeper , not sure if they are still available.can't help you with the gears.Good luck
I'm not Hugh, but maybe I can help.
AFIK the gearing is the same for A thru 140.
The hydro-creeper was mentioned in a previous post. They have not been available from IH for YEARS. Used ones are rare also. I've been around these offset tractors for 50 years and have only seen ONE hydro creeper.
You know that with the hydro creeper you lose the use of your PTO also.
If you are looking to run a rear mounted tiller, get another tractor.
Robert: There is no gear ratio difference from first A through last 140.
Hydro creeper was an option, not a very good one, as the hydro motor operated at low rpm. The efficiency on these units was so bad that a 30% speed difference occured between no load and full load in 1st gear.
There were three different high-low transmissions, one built by IH for use in 404. The other two were after market. Problem with all of these, they either reduced PTO speed along with gear speed, or they worked through PTO thus one could not use PTO.
