FARMALL 350 D
keith V
Just wondering if any one out there could tell Me the best way to get the air out of the lines on a farmall 350 diesel?
THANKS IN ADVANCE
Crack all the bleed plugs on the top of each filter housing as you go from the fuel tank to the final filter. Keep the tank full or near full for good flow.
When you get bubble free out of the last or final filter, crack the fuel line to the injector pump untill you get good flow and then tighten the fitting.
Crack each injector line at the injector and make sure the shutoff cable is all the way in.
Crank it over until you start getting fuel out the injector lines and tighten them one by one. It should start to fire and run.
make darn sure you got fuel to that Roosamaster injector pump before you start cranking the engine. it does not line to spin dry and it sure don't like water. It will snap a drive quill in a heart beat.
If your talking about the injectors, I always took mine to a diesel injection service. I am not that good at the tiny precise things.
