Dan.Nordmann
I have a Farmall 350 utility tractor with power steering.
This winter I seen oil leaking from the oil seals by the arms that connect to the power steering unit.
Well I finally got around to replacing both seals (left and right side) and the leaking did stop from the arms. I thought it was all fixed...haha not.
Turns out I now have developed a new leak that seams to be coming out of the top of the steering wheel. I thought this was weird as this just started happening after I replaced the new seals where the arms connect.
One thing I find strange is this winter when I checked on the oil level that was in the power steering unit it was about an inch from the top. Though...
Checking today, after using the tractor for an hour or so (lots of turning) when removing the nut for the fill reservoir oil came flowing out. So wondering where this extra oil is coming from. It's not water as the tractor is always stored inside. I'm assuming somehow hydraulic oil is getting into the power steering unit. But my question is where. Looking at all the diagrams that show the exploded view of the steering I'm thinking some of the seals are bad where that piston for the power steering is.
Just seeing if anyone has more insight on this. Would there be any other place that hydraulic oil could seep into the power steering unit? I know the power steering reservoir is supposed to be separate from the hydraulic.
If not I guess it's time to start disassembly!
