Farmall 400
tomm222
How much is a farmall 400 worth? It runs great and the ta works but the pto doesn't. It is in need of a paint job but has very straight tin. Has everything. I have not fixed the pto yet.
Hey man you there is a PTO disconnect under the tractor back a little ways from the clutch it is a flat lever about 3 inches long with a bolt located near the end to hold it either in or out of gear you might want to check to see if it is out of gear. I gotta go
1500 to 3000 dollars depending upon the condition.I live in Ky and bought one for 2000 dollars in good condition, even the paint wes good.It was drawbar and I changed it to 2 point fast hitch which also cost $350.
