Inability to lift issue is SOLVED!!
My F450 would not not lift a chipper or a back blade I have. Back in May and December of 2019 I posted questions here and received a lot of good advice and help, but I did not resolve the issue. Life and other things cropped up and I did not get back to it.
Recently, I received a suggestion from a tractor friend (and saw posted somewhere) to look at the check valve for the fast hitch cylinder. When I opened it up, the internal o-ring was completely gone. I replaced the spring, check ball and o-ring and now all is well. The tractor lifts the 950 pound chipper without a second thought.
Now, this also means that I have on my shelf an M&W pump, a set of F450 supply/return lines to connect the M&W, a safety/priority valve, and a fast hitch control valve that all should find gainful employment someplace. Would anyone be able to suggest reasonable asking prices for these?
Randy
Randy
