We have a 450 Farmall that we want to do some pullin with in the 6500lb class,ours has a narrow front end,new 14.9/38 Firestones on 14" rear rims,clutch,T/A and engine are all stock and in great running condition.I am running this tractor on a 14" disc and it performs guite well in second gear D/D,the motor spins at 1650 in neutral.
Ok,the short and sweet here is that I need some advice on ign timing and a good governor setup,maybe just a spring change for more RPM"s as I want to pull this tractor in 3 gear for better ground speed.
