Farmall 450 Steering
Priority valve is bad, that is what is causing your problem, call steel wheel ranch, they can fix you up with the parts you need to fix it
I just fixed the power steering on my 450. The others are correct that it should be your priority valve. I fixed mine on the tractor. Remember in this case it is about flow not pressure. Take the snap-ring off and slid the valve out. Inspect it and make sure it moves freely. Next, take the top off of the priority valve (the square box). Hint; take one bolt out first and get 2 bolts that are about an inch or so longer as there is a spring under the cover. Put longer bolts in oppisit (sp?) corners and take cover off. Clean assemble and make sure oil flows through it. I put a washer under the spring to increase flow. Cost was nominal for the priority valve fix. I probably should have bought a new spring though.
I also had to fix the power steering pump. I took it to a mechanic that was familiar with them and he rebuilt it for about $100.
