Farmall 460 Engine Modifications
Does anyone know if the 221 cubic inch 460 Farmall engine can be made a 301? It seems that you could remove the sleeves and bore the cylinders for the 301 pistons.Has anyone ever done this before?
You will need a crank and rods from a 560 and 301 pistons.You didn't say gas or diesel just pull the sleeves and hone for stock bore 301 pistons or bore for over sized 301 pistons.Will need some type of ring to fill the top flange area.
