Hello all, I have a Farmall 504 gas tractor with issues not starting.
When I push the button to start I hear a click/noise from the
solenoid/starter. Then everything goes dead. The 2 lights on the
dash go dead. I have to disconnect battery cables and reconnect
them to get the 2 lights on the dash to light back up and allow me
to push the button again to try starting. When I have the key on
none of the headlights work either. I have taken the starter off the
tractor and hooked cables up with a jumper wire to the solenoid
and the starter spins and operates just fine. Tractor has sat for 2-3
years with no use or anyone messing with it. Its always ran/started
right up for the last 30+ years. Any suggestions/help would be
awesome. Thank you!
awesome. Thank you!
