Farmall 560 head
Anonymous-0
I have a head off a silver diamond motor... I have a 301 in my 560 what is involved in switching heads . .? What should I run for a carb about 3500 rpm also who has a steel flywheel ? Thanks for your help !
You need all the top end- push rods, rockers arms valve cover etc. You need to check compression with the head and pistons your using. The small chamber really helps bump the compression up. As for the carb, the biggest zenith made might work. I think it flowed 400 cfm, and I"m sure a guy could get more out of it.
Ok. That's the one I have. I'm trying to figure out which one is better. I've got the tilt valve head on my bd240 pick up, but it's a daily driver
