Farmall 560
Just to the right of the shifter, there is a flat three sided plate with three bolts and the check plug is on the left side ahead of the clutch pedal pivot.
Like i luv farmalls said, the triangle plate to the right of the shifter, level check plug is on left side of transmission case just ahead of the clutch pedal. Total capacity is I believe 17 gallons, for the 560 the hydraulic oil and transmission lubricant are one and the same.
