Farmall 656 Overheating Problem
Need some advice....my 656 is overheating...
I have put a new waterpump on it and a new thermostat. Radiator is new, and has new coolant in it. What is next?
How do I figure this out......there is no water in the oil.
from what you have done, first thing that comes to mind is thermostat. New does not necessarily mean good, especially if imported. I would remove thermostat and test by putting in a pot of water, then heating water to see if it opens. A simple candy thermometer will tell at what temp.
Another test is to run tractor without thermometer and see what happens. Good luck.
Are you absolutely certain it is overheating?
My Oliver 1850 suddenly began pegging the temp gage after running 10 minutes or so. Problem turned out to be a failing temperature sender. A new sender fixed the "overheating" problem.
Given all the work thats been done if its boiling over that would be my guess. Some of those leaks don't show up until operating temp is reached.
Then start looking for a cracked head , cracked block or leaking head gskt. If the rad is clean and ya have a new T stat and water pump and no bottom hose colapsen . I would remove the T stat unhook the water pump and fill with water to the top of where the T stat sets on a COLD engine and start it , once it has smoothed out nail the throttle wide open and if it pushes water out then ya have a problem . If nothing blows out then change the gauge and see what happens.
(quoted from post at 08:53:09 08/01/13) Need some advice....my 656 is overheating...
Change the sender.
