Farmall A cultivator?
I am trying to piece together a manual lift bracket for a cultivator on a Farmall A. I have the front cultivators attached to the bracket but can't figure out how to attach the rear cultivators. What does the flat bar in the photo that goes to the rear attach to? I think that the rockshaft that is on there now is the wrong one for the manual lift bracket I have but I think that I have the correct rockshaft for it (shown in other photo). Can anyone tell me how to attach the rear rockshaft to the flat bar going to the manual lift lever? Also how to attach the other rockshaft to the tractor? Pictures would help, but I would take any information that you guys might have. Thanks.
You dont have the correct rear rockshaft for the bar going across the rear wheel doesent have anyplace to fasten.You need the one with the bent arm on the left side. I have one if you need to buy one or you could weld one on yours.
Been a few years, but I think that you have the pieces turned about 180 for the rockshaft. Put the piece on the right side of the second photo to the right side of the tractor. The flat curved bar will pin on the arm on the left side of the rockshaft in the photo. Long flat bars on the supports go to one of the bolts where the tail plows attach. Then there is a bolt or bolts that attach to the transmission housing or fender.
