I'm working on a Farmall A. Got done overhauling the engine, ground the valves and seats, and took apart the rocker arm assembly and cleaned it up. Put everything together and had terrible compression on most cylinders. Took the valve cover off thought maybe I needed to check valve lash again, but no some of the valves were stuck open.
Took out one of the push rods and the valve is fine and rocker arm, it is the lifters sticking down below. If I push the push rod down it goes back down but is definitely tougher than it should be.
Right now I'm trying to pour penetrating oil, mystery oil, etc down while cranking to try and lubricate the lifters. I really would like to avoid having to tear the thing apart to pull the cam.
Any other advice? Anyone else ran into this? I thought about dropping the pan, but I don't think that will help?
Thanks,
Noah
Thanks,
Noah
