I have a Farmall Model A, crank start. It seemed to be overheating and the engine would stall out. I took the radiator and had it acid dipped and cleaned out. I cleaned out the water jacket with Washing
Soda and hot was as directed in the manual and flushed it out with a lot of water. I put on a new fan belt. It is quite tight with 3/4 inch play as the manual says it should have. I have a mower deck. It
starts well, but after mowing 15 to 25 minutes the engine seems to start choking out. The engine will idle unevenly while siting, but it will die out with a load on it. Seems like something is getting hot and
causing the stall out. Any ideas.
