I have a couple of issues with my B. It is a 6volt, and I am having starting problem. I can only get the engine to turn over 1 revolution (if that). When starting. I have cleaned all connections, charged battery, etc..
I am wondering if the engine could be too hard to spin for the starter?
Checking out this possibility, I decided to loosen the generator belt. It is very tight, and see if this frees up the engine/starter. The problem is the belt is tight and the generator has no more travel to loosen. So I have no idea how the belt was put on to begin with. Doe the radiator need to be pulled to put belts on? Should the generator have more travel? Many questions thanks for reading.
tshlance
tshlance
