farmall BN starter
Just to add one more a starter off an H will also fit. I know because I have a starter off a B on and H. The starter from an H is a heavier duty one then what would be on a B/BN but will still work and probably last longer
Hobby farm
If you want the original with the kick rod that pushes the starter sw the only one the same is from an A or B. The C.SC.SA and newer ones have a pull rod thus the button for the sw is on the rear. The H uses a threaded post and needs a heavy sw or a solenoid to operate.
