farmall c governer
Hello, I was plowing to get my garden ready. I run a farmall c and the rpm just went to idle. I looked the linkage over and it was moving the arm I think on the governer but was not moving the arm to the carb. Is this a easy fix if I take things apart or do I need some parts? any help appreciated. thanks.
I-H dealer and be sure to hook the new one the same as the old one with the hooks facing same way or it could bind. Be careful not to move the gear that drives the gov or you will be out of time bad. Its not easy to remove the housing but it can be done you will have skinned fingers guranteed. Mite need to replace the thrust bearing also. Spring loaded pin needs to be free on the end of the shaft.
