FARMALL C PULLER NO POWER!!!!!
ChrisW
i have a Farmall c that im pulling now with the C-153 motor in it, has good oil pressure smooth running starts quick, should be around 65-70hp but now the last few pulls its going down hill fast last pull it choked out on me in 2nd gear yesterday it chokes out in 1st in the 3000lbs class. well anyways i just wanted to see what everyones input was on my situation, its a good fresh "10hours" rebuilt motor did great all last year!!!!
thanks alot and i hope you or someone you know has some ideas.
THE ONLY WAY THAT SUPER C IS MAKEING THAT HP IS WITH A COMBINE MOTOR! I WOULD THNK A S C MOTOR DONE WITH GOOD PARTS WOULD BE AROUND 30 HP. LOVE THE SUPER C I HAVE ONE. REAL HANDY AROUND THE FARM.BUT NOT GOOD PULLING MATERIAL UNLESS YOU HAVE DEEP POCKETS.
Your Distubitor Tight?
Carb Ajusted ok?
Maby you had help tuning it!
How maney Cubes you Got?
Usualy takes 200 Cubes For That Much HP!
Your C is doing just fine. The other guys redid their motors last winter so the sled operator had to raise his gearing in order to stop them, so you can now get only a half track.
In addition to the other suggestions, might I add these; Were the valves lapped in and are they set right and sealing properly? Also, did you re-torque the head? Might be time for a compression check.
We had a guy that pulled in NW Illinois in the late 80s with a B and the combine engine. I watched him dyno into the 60hp area and could hardly believe it. Thus said this doesnt surprise me with 20 more years of advancement.
I had an M that did the same thing as your tractor. It didnt have enough power to load itself. My carb guy spent 2 or 3 days on the carb before he found a blocked passage. He never did see the blockage but heard it bounce off the wall when he put enough air pressure to the passage. I had a plastic T fitting in the fuel line for a second tank and the T "rotted" away and plugged the carb. replaced my lines and used brass connections and never had that problem again.
