RAMacGregor
Thanks to everyone who provided their thoughts as to my clutch adjustment problem before I split the tractor (F544); it appears the remanufactured pressure plate had a bad finger.
Turns out the operator's platform was bent; I have it just about back to where is should be, it is still affecting the travel of the clutch, but is much better. My question
relates to the throw-out bearing. Should there be zero movement of the bearing when the clutch is not engaged? If I look under the tractor while it is running, I can get the
fingers about 1/16 - 1/8" away from the bearing, but it is not quite enough to disengage. A couple more turns on the yoke, and it is fine, but the fingers just barely touch the
bearing. It will turn slightly, and stop, or another half turn on the yoke and it will spin. I can carefully put my finger on it and it completely stops. You can watch/feel
while pulling the pedal down with your hand that there is no actual pressure on the pressure plate springs. It went well, but I don't want to split it again anytime soon. Thanks!
