Farmall Cub runs
mschwartz
Cleaned the fuel tank, sediment bowl and carb. Made new battery cable, filed the points and it still would not start, looked closer and someone had the firing order on the cap set wrong(1234). Moved wires around correct and it fired right up. Son was happy with it, Mike
Many times the simplest things are the problem. Where I used to work before retiring, we ran a Cub with a Woods belly mower for over 30 years. Engine got rebuilt twice during the time I worked there. That Cub mowed a lot of grass around the city.
They all hold air temporarily, I think one rear will be ok, weather check but not horrible. The other rear and both fronts are shedding rubber onto the driveway and will need to be replaced before we run it much more. Should be able to save the tubes.
