farmall gears.
guest6789
Want to know if you can mix and match different gears from a M, super M, W6, and super W6?
Would it be possible to run 2nd from an M in 1st gear position, and 2nd from a super m in 2nd gear position, and 3rd from an M in 3rd position?
You would likely have to build custom gears to do this. The 1st/2nd driver on the countershaft is a compound gear. The 2nd/3rd sliding gear on the mainshaft is also a compound gear. In other words, 2nd gear is not a stand alone gear set on either shaft.
Zack
