Farmall H Hydraulic Drain Plug
rlk
Can anyone tell me where the hydraulics fluid drain plug is on a Farmall H ? I looked all over for mine this afternoon and have not found it. (I know it is not hydraulic fluid, but motor oil.)
Thanks, Bob
Looking at it from the back side it is on the bottom of the pump left side. Usually a pipe plug with square head
In addition, the return line is sometimes ran to the drain plug hole. Hopefully if they did this they used a tee fitting to allow you to still drain the fluid without taking the hose off.
There is a 90 degree elbow and hose screwed into this one:
Some body used the drain hole for the return line for aditional hydraulics....they should have used a T and pipe plug....the original system uses 30w engine oil.....
Thanks Don, Steven, Scott & Dave. I finally found mine. The plug was rounded off, and did not look like a drain to me.
Bob
