Farmall H no fire at points
Anonymous-0
Lights, possibly ignition switch, left on overnight. After charging batt back up, she turns over fine, but no fire at points. 12V conversion w alt. several years ago.
Checked continuity across poles of switch, in the wire running from switch to coil, and across terminals of a ceramic resister by the coil that has something to do with the 12V conversion. All of these continuity checks are ok, but still no fire at points. Tractor ran fine yesterday before we ran the batt down.
1) What could be the cause of no fire at the points? They are opening up normally as the engine cranks over.
2) What does the condenser do? Could it be the culprit?
3) How do I test the coil to make sure it is good? It isn't very old, as it is a 12V coil that was installed when converted to 12V.
4) I need to get the old girl out of my Dad's shop before he just yanks it out.
Thanks in advance,
Young Tom in Iowa
I'd say points are burnt.If ign is left on with points in certain position,they will fry.
File them lightly to see if fire re-appears.If so,replace them.
i bet ya burned up the points just cause they are opening dont mean they are good i would take a emery file and file the devil out of the points first. you can take a test light and connect the alagator clip to the post on the dist. and put the other end on the positive side of the battery then crank the engine with the switch off the test light should go off and on every time the points open and close if it does go on-off its not the points
You need to check for voltage at the coil with points open. Should have voltage on both small terminals. Run some 320 wet or dry through the points until shiny. If they're pitted replace them and the condenser. Hal
PS: You need the ignition switch on when checking for voltage.
Young Tom,
If the ignition was left on the coil may have got too hot AND/OR the points may be burned, Id try to clean/light file/polish n re gap them n try again..... If the coil has that classic burned electrical smell it may be bad/open cuz the primary winding got too hot !!!!!!!!!!!!
The condensor prevents the points from premature burn up (plus other electrical things too complicated for here), if not there they would burn up pretty quick. She will still fire albeit weaker if theres no condensor at all but if its shorted out that kills the spark. It can be the culprit but I suspect if the ignition were left on the coil or points is the more likely problem for now at least.
A ohmmeter will tell if its BAD BUT NOT IF ITS GOOD. The primary resistance as measured between the lil + and - terminals on a 12 volt coil will be around 2.5 to 3.5 ohms UNLESS ITS BURNED UP AND OPEN which may happen if it got too hot. HOWEVER even if she passes low voltage ohms checks dont mean she may not still break down at high voltage and temperature, the ohms test ONLY shows it its badddddddd like a burned open winding. SEE COIL INFO IN POSTING BELOW
NOTE when converted form 6 to 12 volts you have to EITHER add an external series voltage dropping (12 to 6) Ballast Resistor if you keep the old 6 volt coil OR ELSE use a full true 12 volt coil BUT NOT BOTH... i.e. if its a 12 volt coil DO NOT USE THAT BALLAST it will make for a weak spark..
NOW if thats not enought heres a Troubleshooting Procedure to run if shes not firing
TROUBLESHOOTING A BATTERY POWERED EXTERNAL COIL TYPE IGNITION SYSTEM:
PRELIMINARY CHECKS:
(A) To see if it happens to be a cap n rotor problem and to see if at least the coil is firing, remove the coil wire from the distributor (leave coil end intact) and place its bare end to within 1/8 inch from tractor iron, turn her on n crank her over, and see if she jumps that gap with a good visible blue spark?????? If so but the plug wire ends (from wire end to 1/8 inch to frame) or the plugs themselves don’t fire, its a cap n rotor or plug wire problem. If the coil wire isnt even sparking, see below.
(B) Next open the cap and see that the points are gapped correct and indeed opening and closing as the engine is cranked and the distributor shaft rotates and MAKE SURE THEY ARE NOT BURNED OR PITTED OR CARBONED UP BADLY !!!!!!!!!!!! If so, running a point file between them to clean them up might make her run again HOWEVER that’s only a temporary cure, so if that cleaning makes her spark, INSTALL N GAP NEW POINTS. In the event they appear good but only gray oxide coated, non abrasively clean/buff/polish them using say a dollar bill or shop cloth etc. and see what happens.
MORE TROUBLESHOOTING IF ALL THE ABOVE STILL FAILS TO MAKE HER SPARK
1) THE VERY FIRST THING YOU GOTTA HAVE is voltage to be present on the coils high supply (NOT to distributor) terminal when you turn the Ignition switch ON. If not she cant ever fire, but in the event the ignition switch or circuit/wire down to the coil or any Ballast Resistor is bad or open, you can HOT WIRE it by jumping a hot ungrounded battery voltage source to the coils high input supply (NOT to distributor) side n see if she runs then???? If she fires hot wired, you could have a bad ignition switch ((That can happen, when Ignition is on, the switches IGN terminal must turn hot)),,,,,,,or an open Ballast (if it has one) or a bad/open wire from switch to coil.
If the switch is good, if you turn the ignition switch on and place a test lamp on the coils high (NOT to distributor) terminal SHE MUST LIGHT UP. If not again, look for an open Ballast Resistor (if it has one, it should read around 1.25 to 2 ohms across its terminals) or bad/open wires from the switches IGN output down to the Ballast (if it has one) and distributor.
2a) When the Ignition switch is turned on, voltage should appear on the coils high input side. That would be 6 volts on a straight 6 volt system or 12 volts on a 12 volt non external ballasted system, or around 6 volts on a 12 volt system that used a 6 volt coil plus an external Ballast Resistor and the coil is good and the points are closed and they and ALL wiring is good.
2b) To insure the coils low voltage primary winding is not bad/open, use an ohmmeter and measure its DC resistance between its lil + and -terminals. If its an open circuit (no continuity) its bad/open and will NOT work. It should measure around 1.25 to 2 ohms or so if its a 6 volt coil and maybe 2.5 to 3.5 if its a 12 volt internally ballasted coil. NOTE CAUTION have all leads and any voltage source DISCONNECTED FROM the coil for this simple primary winding continuity test.
3) Next, place your voltmeter or test lamp over on the coils other low to distributor terminal side, turn her on and crank the engine over.
4) A test lamp there should flash ON (when points are open) and OFF (when points are closed) as the engine is cranked slowly.
5a) If the lamp never comes on there, the coils primary is bad/open,,,,,,,,,,or the points are never opening,,,,,,,,,or theres a shorted/bad condensor (remove its lead to points and see if lamp comes on, if so, bad shorted condensor or its wiring),,,,,,,,or the points wire is shorted,,,,,,,,or the distributors side pass thru stud is grounded (use ohm meter to test that),,,,,,,,,or the points may have a shorted spring.
5b) If the lamp never goes off as engines cranked, the points are not closing or are bad,,,,,,,,or the wire or circuit is missing from the distributor to the points,,,,,or the distributors not well grounded to the tractor.
She cant fire the coil unless its low side is getting a conductive ground return path via closed points and then the circuit is open when the points open.
Be sure the condensor or its wiring is NOT shorted out and see if the lite comes on (when points open) with the condensor disconnected. If removing the condensor makes her spark, replace the condensor.
SUMMARY
Be sure the points are closing fully and open on high cam and ARE NOT BURNED OR PITTED OR CARBONED UP BADLY,,,,,,,theres voltage present on distributors high side at all times when ignitions on (or its a bad switch or open ballast or bad wiring to col),,,,,,,voltage on coils low side flashes on and off as distributor is cranked,,,,,,,,,condensors not bad/shorted,,,,,,,,no shorts in wires to points and no shorts in pass thru side out distributor stud,,,,,,,,coil has continuituy.
You may luck out n just need a new set of points. If the coil wire fires (see above) and the plug wire ends to 1/8 from frame but NOT the plugs, they are badddddddddddd. Check them BOTH.
Good Luck n God Bless, post back any questions and your findings and any questions.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks over on the Mother Deere boards versus over here on the “dark side”.
You would be very unlucky to leave it with the points making poor contact, thus being a high resistance to earth and hence overheating and burning. The condensor is designed to stand much more voltage than your battery potential and should simply do nothing while just your battery voltage is applied.
That leaves the coil and ballast resistor, both of which were probably carrying much more than normal operating current, continuously until the battery became discharged.
It is likely the coil has overheated and gone bad as it is designed as an inductor, not a plain resistance load.
If the ballast has gone west then it should start by tempoarily shorting across the ballast, or should start via the auto-short (ballast bypass) system for starting if the conversion was done properly.
Continuity is not everything. Current measurements are much more appropriate (or voltage measurements if you know what you are doing).
Measure the current through the coil with the points closed and open. It should be around 4 and precisely zero amps, respectively. If it is zero and zero, check by directly shorting the points side of the coil to earth. The readings should isolate the faulty component - points or before points. Working systematically along the system will eventually find the fault.
You may have other 'high resistance' connections giving trouble in the circuit also. They can easily add up to 'not enough energy' to fire the plug.
Try and isolate the fault before running out and buying a new coil, or filing the points, or whatever. It is much more satisfying (and plain sensible) just to find the fault and fix it rather than tryng several fixes and finishing up worse off than when you started, 'cos you changed something else, as well, while fiddling.
Regards, RAB
Had same problem and thought it was the coil. Replaced it and still no spark. Replaced the condenser, which was only a week old, and fired right up.
