Big Red Man
The Starter button on my H (located at the bottom and behind the steering post) went from 1939 until a couple of years ago. I replaced it and mounted it to the steering post like
later ones. I used an after market mount bracket and heavy duty cables. Recently when I pressed the button nothing happened. I twisted and tapped on the button and it started a
couple of times. Then it wouldn't and it began electrical fritzing/sparking seemingly between the mount and the steering post. Yesterday I removed everything, took a flap grinder
and cleaned up all connections and put everything back together. NOTHING!!! It will click or clack, but not turn over the engine. Hand cranking works, but isn't fun. Should I just
get a new starter button, or what the heck is the problem??? Thanks, kelly
