Al_husak
I have a farmall H, itll start up and run good for about 5 mins
and when I hook up to something or down the road it will begin
to stall out and I will choke it and idle it and it run
good then I begin to take off and it will happen again. I have
replaced the spark clubs, rebuilt the carb, blew air through the
copper line, cleaned the bowl, and has fresh gas.
What"s wrong ?
Try this. Sounds like carb adjustment needs to be performed.
FARMALL H & M CARBURETOR & GOVERNOR ADJUSTMENTS
Note: #1, 2, & 3 adjustments are done with the engine not running when the carburetor has been removed & replaced.
1. Loosen the 2 screws that are holding the governor tube to the governor housing. The clamp is slotted to allow adjustment. Tighten the tube-to-carburetor screws; gently tap the tube so it "centers" itself, & then tighten the tube-to-governor screws.
2. Remove the top cover on the governor housing (has the pipe going to the cylinder head) and check governor to carburetor synchronization. Remove the cotter pin so the clevis pin can be removed. With the operator's throttle lever set wide open and rotating the horizontal rod upward to wide open throttle position, the clevis pin should just slip into the rod that is in the tube. This horizontal rod should rotate freely allowing the carburetor throttle plate to move from idle to wide open. Adjust the clevis height if needed & lock the nut. You may need small fingers & right-angle needle nose pliers to make the job easier. Return throttle lever to idle. Re-attach the top cover.
3. Carb adjustment: idle air screw is set at 1½ turn out to start with; high speed mixture screw is 2½ or 3 turns out.
4. With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw (on the bottom facing down to the rear) in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out ½ turn or more beyond the "sweet spot" to be sure the engine isn't starving for fuel and can develop its rated power.
5. The same procedure can be followed for idle air mixture with the addition of setting the idle stop screw (just to the rear of the governor shaft tube) to adjust the low speed RPM.
On the "H"& “M” carb, the idle air mixture screw (faces to the front just below the idle stop screw) is an air adjusting screw so turning in will richen the mixture and out will lean the mixture.
Repeat the carburetor adjustment procedure again to make sure “all is well”.
Did you set the carb float to the correct setting? I have had the float hang up on one of my H"s.
Remove the plug on the bottom of the carb, you should have a steady stream of gas running out.
I would check your ignition timing, make sure the mechanical advance is working properly. If you're not sure how to do this see if you can find some one that knows about this items.
(quoted from post at 17:56:09 05/30/13) I have a farmall H, itll start up and run good for about 5 mins
What"s wrong ?
Take a flashlight and look in the tank for anything that may be sealing off the gasoline inlet. Could be?
