Gtidwell
This may not be enough information but I hope so for information. I met a guy today at a small tractor show. He has a Farmall H that has a single wheel front end. He says it is a running tractor. He has all the sheet off and it is straight and premiered. He says the only thing is that the steering needs some work and parts. Are the parts to possibly fix available? I can pick this tractor up pretty reasonable. Would it be worth getting? I have not seen a single wheel before myself.
Single front wheel is not common but not rare either. Steering is a common problem. Parts are iffy but used parts are out there. I have 4 H tractors for sale. All 1940 and 3 ran when parked and the 4th is parts
The single front is not un-heard of. But I have seen very few in my day.
I'm guessing the work and worn parts he is referring to, thats needed to fix the steering, has to do with the upper portion of the steering. The worm gear shaft primarely. This is a common wear problem on the H. If you can find a stock new one, it'll probly be to expensive to buy. But if this one is worn REALLY bad, your best bet is to just find a used one that is not as worn as bad as this one. And that could be found fairly easily in a salvage yard. It won't be like new, but way more cheaper. Thats my 2 cents.
I guess you have to ask yourself if you want an H?? Lots of them out there. A single front wheel does not add any value, honestly it means I would need to find a different front end and swap it out, so maybe negative value. Steering issues can be fixed, but an H steers pretty easy and if it is wore it has a lot of use, but it is fixable. IH made half a million Hs, lots of parts. To me reasonable would be less than $400.
The steering parts are not hard to find all you have to do is click the ..Tractor Parts.. box at the top of the page. I will make it easier yet and give you a link you have to scroll about half way down to see the worm shaft which is $146, that is the cheapest price for that shaft with one exception being YTs biggest competitor. The gear further down at $93. Not cheap, but available. I will add a second link for the CNHI parts diagram. Running Hs on auctions start at $500 for a rough specimen and go up to $2500 for real nice restored ones, most runners without shiny paint go
In the $600-$1000 range. The thing about this tractor is you are basically committed to painting it unless you are okay running around with a primered tractor. So you may as well at a minimum add $500 onto your investment right up front. One big factor you do not mention is the condition of the rear tires, a new set is at least $1200. As Matthew said you have to decide if you want an H that needs work done to it?
YT Farmall H steering parts
CNHI Farmall H online diagrams
Go for it.
You can never have too many H's. I have three.
And you can get most steering parts right her on YT.
One simple trick to tighten the steering on an H or M is the round gear at the top of the pedestal has teeth all the way around, but only half are used at any given time. Unless it's already been done, pulling the gear, turning it 180 degrees, and reinstalling it has the effect of installing a new gear.
Single front wheel Farmalls stress the steering gear more than narrow fronts or wide fronts because the wheel must spin in place. Especially when stopped, so the wear is worse. Jim
Agree with JAN in theory but my experience with H's and M's with cotton pickers is a bit different. Either tractor with a single front will steer easier than with a two wheeled tricycle front (unless on a flat surface)when cultivating, spraying or with cotton picker. Put a single sweep in the center of the row-middle when cultivating and the single tired tractor will follow the furrow with very little effort and without fighting for the furrow. Put a ridge in the row-middle and the double wheels work OK for cultivating or cotton picker but will fight in a sharper turn. Sitting still, the single wheel will be hard to turn but move it an inch or two and all the tire turning is overcome by the caster effect. Make sure the caster is to the rear of the direction of travel and the stop bolt is in the proper position. Cotton pickers need weight on the steering tire to counter-balance the row unit, but will add perhaps up to 800 to 1000 lbs as the basket fills. I have never seen a cotton picker without a single wheel steering unless it had power steering on the tractor or a wide steering axle. Not many H's or M's had power steering from the factory. As others have said, good bushings and thrust bearing on the bolster, good U joints and bearing on the steering shaft with a good or less worn top gear and all will be good. Not all top gears are 360 degree gears. Wheel bearings are more difficult to change, but dealing with only one tire to purchase with single wheel. Some will argue that you can limp home with a dual tricycle with one flat or wheel bearing gone bad, but don't count on going very far.
