javan
just put a diff motor into an "H" that blew up 20+ yrs ago. the motor runs great but the tractor doesn't move. I looked under the tractor through the insp. hole and the shaft goes into the motor does not turn (with the trac running) is this right? If it is supposed to be turning why isn't it???
There behind you on the shop floor is a u-joint looking thingy, if the kids haven't carried it off, put it between the clutch and trans.
