i need some help on timing my pulling tractor i know how to time them good for farming but someone sais to advance it a little bit counterclockwise? if so how much? ...i got a farmall 350 head bigger valves,electronic ignition,delco distributor,"gas" manifold. bigger guts in carburetor.rpm is 27-3100 thanks alot guys.
Do you have a roller dyno for cars or big trucks around. At the local cat shop they dynoed a M Farmall because it would snap the pto off. Just use 4th gear as it is the closest to 1 to 1 ratio.
