Looking at getting an old M running for some low key local pulls. I have an 8060 head that I want to use. Is this head from a SM or a 400? Looking at shaving it .65 to .80. Also is the block bore of the M, with the sleeves removed, the same as standard pistons from a 450 engine ? If so will this head work with the 450 pistons or will there be clearance issues?Also I am confused on the wristpin bushing thing!Will the 450 pistons work on the M rods? With or without pin bushings?Also where is the best place to get those counterbore rings you will need for the block? Any other suggestions appreciated. Jim.
