redforlife
I'm not a fan of in-line filters 'because' that I don't think they work. I'm not a fan because I don't think they are needed. In all honesty, the glass bowl to catch the bigger particles is all that is needed. It itself, catches some pretty small particles. Fine sand, rust particles, etc. I've cleaned the tiniest of stuff out of the bowl when getting rid of the build up.
It's not like we are talking about something with fuel injection here. System is much simpler than that.
My beef about adding something that is just not needed is, it's just more headaches in the troubleshooting department when you do have problems. You add an in-line filter, and that's going to be the first thing you check when your tractor quits running (problem there or not). Reason you'll check it first, is only because it's the easiest to check first. If it wasn't there (and really don't need to be), you wouldn't have to check it at all in the beginning each and every time you have a problem. And that is where your just adding grief with no benefit.
