Farmall M Puller
Got a question. I have a Farmall M 450 block LP head. MSD box, points. 4.38 bore and six in stroker crank. I am having trouble with the engine shutting down. It is dieseling. I have am having to put into gear and kill it when I hit kill switch. Any help would be apprecaited. I dont know what to check next. I have checked timing and have adjusted idle to as low as I can get it. Any help would be greatly apprecaited.
Yes, A higher octane gas should solve ur problem. We had a D19 Allis puller once, it had regular gas in it and it pinged(detonated) very badly. We decided to chec to compression, so I pull the coil wire off and stuck my Snap On conpression gauge in and hit the starter. The engine started on 5 cylinders with no coil wire. Broke the compression gauge too. 93 octain is good for about 200lbs of compression. Your timming may be a little high also, you might want to check the advance in the distributor to make sure it is working correctly. Hope this helps.
I am running just over 200 lbs of compression in each cylinder. I bought some 110 octane gas today to see if this helps. I guess more compression the more octane you need. Thanks to all who helped.
Someone correct me if I am wrong, but higher octane equals harder to ignite. That is why you run high octane in high compression engines to keep the fuel from pre-ignition. So in your case higher octane might help as your engine is essentially turning into a diesel. When you kill the ignition and with your compression it is continuing to detonate the lower octane (easier to combust) fuel and continuing to run by compression ignition.
run e85 in it alot cheaper than race gas,if you have high compression you will need to retard the timing also timing needs to be set with fuel you are using differnt fuel needs different advaance
these are different fuels and their octane ratings
Chart #1
Octane Meter Reading
Shell Premium (Chicago) 93 -8
Shell Premium (Lafayette) 93 -36
Shell Plus (Chicago) 89 -14
Shell Plus (Lafayette) 89 -39
Shell Regular (Chicago)
87
-11
Shell Regular (Lafayette) 87 -41
Amoco Ultimate (Chicago) 93 -22
Amoco Ultimate (Lafayette) 93 -40
Amoco Silver (Chicago) 89 -8
Amoco Silver (Lafayette) 89 -44
Amoco Regular (Chicago) 87 +83
Amoco Regular (Lafayette) 87 -39
Phillips Premium (Chicago) 92 +82
Phillips Premium (Lafayette) 92 -45
Phillips Midgrade (Chicago) 89 +71
Phillips Midgrade (Lafayette) 89 -42
Phillips Regular (Chicago) 87 +69
Phillips Regular (Lafayette) 87 -40
Unocal Race Gas 110 -46
Cam 2 Purple 114 4
Cam 2 Blue 116 -20
Phillips B32 Race Gas 108 -43
ERC Purple 110 -36
ERC Blue/Green 114 -14
With higher "octain" you require MORE timing due to the fact it is a slower burning fuel.
This includes E-85 and all race fuels.
You never retard timing for better fuels.
You retard for spark knock.
You retard when it won't start due to it being hot .
To reep the benefits of e-85 you will throw more timing at it then you ever thought you would.
Down side, it will use alot more fuel..
Is it converted to a 12 volt alternator and miswired,
with the alt. feeding the coil, bypassing the ign. switch?
Too hot of a plug or some other sharp edge in the cylinder glowing hot enough to ignite fuel without sparky?
4.38 bore and a 6 inch stroker will make 200 psi by itself with a 8060! You should be up 250 or better with that.
No, dont run E85 straight, mix it one to one gallon with 93 octane. Alot better results, and stop run on from low octane. You might even pick up some power with the retune with the mix.
Pull all the plugs out, open the throttle up all the way and retest to know the exact cyl pressure. 50/50 mix has ran 300 psi worth of cyl pressure on farmalls with no troubles.
I agree with cody the timing is to high for the octane rating on the fuel your using. heck this new motor of mine had no plug wires ignition box or fuel system and fired on the assembly lube when cranked over by the starter.
If you port and polish the head you will have good results with a lower octane fuel. I've seen an engine with 11:1 compression that was ported and polished (so there was no "hot spots" in the combustion chambers) run like a dream on 87 octane. But probably more practical to up your octane vs paying a machine shop to p&p the head.
