Well the generator is shot on my MD and I can"t seem to find a rebuilt one for it anywhere online. Dont really want to buy a used one so I am left with rebuilding mine or switching to an alternator. What do you guys think? I would prefer alternator but but have had no luck finding a new wiring harness for an MD w/alternator. How difficult are generators to rebuild and is it something I could do myself??? Thanks!
When I purchased my Super C it was a non-running tractor and one of the issues was a bad generator. I hand cranked it for the first year after I got it running before having the generator rebuilt. We have a nice auto electric shop in town known for quality work and being a farming area they do a lot of tractors and have a lot of part stock. I'm assuming your generator is a Delco Remy and parts should be very plentiful. Mine needed a new armater which had to be ordered in. After putting in new brushes, bearings, etc. and the armater it has been trouble free. I would suggest keeping the generator system as once you convert them over to an alternator several unknown and hard to find issues can crop up like the battery going down, won't charge, etc. I doubt you will find a ready made wire bundle for MD with an alternator unless someone will custom made one for you. It is something you will have to make yourself along with the mounting alterations. A good auto electric shop can make your generator good for several more decades of use. Good luck and hopes this helps, Hal.
It depends on what is wrong with the generator. If the field or rotor are shot then I would get a professional to fix it. If it needs the commutator (The area where the brushes ride.) machined you can do it if you have a lathe. Remove only enough of the copper that is needed. After machining you need to undercut the spaces between the copper by about .030" or so. And, if needed, replace the brushes.
Matt, I forgot to mention that my 6 volt generator overhaul was something less then $100 a little bit. As I recall my new armater was something around $60 so that was the bulk of the expense if needed, Hal.
I just took mine to a starter and alternator repair shop in Beloit, WI when it was bad. He rebuilt it and had it back to me before the day was over. There is also a place in Burlington, WI that does great work that I have taken other generators to. I actually got my SMTA generator from NAPA and I have no complaints about that one either.
I have an alternator on my MD and would personally never go back to a generator. It's a 3 wire (with an exciter switch mounted on the amp box) so you have to remember to flip the switch on and off to get the alternator to charge the battery. That's the only drawback. You can also get a 1 wire self exciting alternator from the Brillman Co. 888-274-5562 with mounting hardware and, I think, the necessary wiring.
Could be an easy job, or somewhat difficult. You will have to open it up and look at it. Sometimes you get lucky and a good cleaning, a bearing, and a set of brushes are all you need.
If money is a major factor figure 80-100 for a repair shop to do it. FIgure 25 if you do it and the armature and coil are OK.
