You need fuel, spark, and compression for an engine to run do you have all of those and is your firing order correct??Hello I've been working on my grandfather's farmall super a I've gotten it to get spark at plugs has a good blue spark new carburetor can smell gas on plugs and even put either in engine but still won't fire i even gapped the plugs too
Well i have replaced cap,rotor, points ,condenser could i have changed the timing that way ?You need fuel, spark, and compression for an engine to run do you have all of those and is your firing order correct??
I put starting fluid in the intake even tried taking plug out and putting starting fluid in there still wont fire .could that mean its out of timing?Well i have replaced cap,rotor, points ,condenser could i have changed the timing that way ?
The plugs are firing good blue sparkI put starting fluid in the intake even tried taking plug out and putting starting fluid in there still wont fire .could that mean its out of timing?
Did you get the link to the Blue Ribbon Service Manual in the reply I sent in reply to your PM?I put starting fluid in the intake even tried taking plug out and putting starting fluid in there still wont fire .could that mean its out of timing?
Yes but if you think the timing is off thats what I'll do thank youDid you get the link to the Blue Ribbon Service Manual in the reply I sent in reply to your PM?
HOPEFULLY, you did, it contains instructions for timing the rotor gears and timing the mag to the tractor.
Very common now days for a new condenser to be bad right out of the box. Put the old one back in and see what happens. As for timing if you didn't put the plug wires on the distributor cap the same as they came off you have the firing order messed upWell i have replaced cap,rotor, points ,condenser could i have changed the timing that way ?
It says cylinder, one top dead center and ajust rotor to fire cylinder one i watched it on YouTubeYes but if you think the timing is off thats what I'll do thank you
But the plugs are sparking a blue sparkVery common now days for a new condenser to be bad right out of the box. Put the old one back in and see what happens. As for timing if you didn't put the plug wires on the distributor cap the same as they came off you have the firing order messed up
if you didn't put the plug wires on the distributor cap the same as they came off you have the firing order messed i did
Why wouldn't if firing with starting fluid in hooked a spark plug tester on it it was firingVery common now days for a new condenser to be bad right out of the box. Put the old one back in and see what happens. As for timing if you didn't put the plug wires on the distributor cap the same as they came off you have the firing order messed up
Tractor in Neutral. Pull the plug out of #1 cylinder. ground the plug to the block with its plug wire on it. Put your finger over the #1 plug hole and crank the engine over. Does the plug show a spark at the same time your finger is pushed off the plug hole? If not, the timing is off.It says cylinder, one top dead center and ajust rotor to fire cylinder one i watched it on YouTube
If you didn’t unbolt the main part of the magneto off the tractor you couldn’t have changed the timing. Only the gears that drive the rotor can be off. Also a plug can fire outside the cylinder but under compression it takes more voltage to fire the plug. Usually it is agreed that if the spark can jump a 1/4” gap off the the coil wire terminal or at the plugs that is adequate to fire under compression.Well i have replaced cap,rotor, points ,condenser could i have changed the timing that way ?
The cylinder had to be on top dead center of the compression stroke. The piston is also passed by TDC at the end of the exhaust stroke. The compression stroke can be felt by holding a thumb or finger over the plug hole and then cranking the engine slowly with the crank if possible. When air pushes out that is the compression stroke. Then turn the engine to TDC. This should all be good if it you didn’t pull the mag off and it was running for your grandfather. The other thing is the valves could be stuck open. Take all the plugs out and hold a thumb/finger in them and crank it. They should all give a good blast of pressure past your fiinger. You need at least 3 of them pushing air maybe two would work for it to start.It says cylinder, one top dead center and ajust rotor to fire cylinder one i watched it on YouTube
Thank you will try thatTractor in Neutral. Pull the plug out of #1 cylinder. ground the plug to the block with its plug wire on it. Put your finger over the #1 plug hole and crank the engine over. Does the plug show a spark at the same time your finger is pushed off the plug hole? If not, the timing is off.
You've got the factory maIt says cylinder, one top dead center and ajust rotor to fire cylinder one i watched it on YouTube
"If you didn’t unbolt the main part of the magneto off the tractor you couldn’t have changed the timing."
Somebody MAY have swapped around the sparkplug wires since the last time it successfully ranwas running but not good
Been 3 years since it was running. I didn't remove the magneto and thank you for the adviceYou've got the factory ma
Somebody MAY have swapped around the sparkplug wires since the last time it successfully ran.
Yes I did thank youDid you get the link to the Blue Ribbon Service Manual in the reply I sent in reply to your PM?
