Farmall Super H
John69
I have a 1953 Super H that holds really good oil pressure, but smokes, white smoke. Sometimes the choke will vibarate out, and I push it in and hold it in, and it will quit smoking, and sometimes it won't quit smoking; doing that. Does it have to be that I need to put a set of rings in it?
Blue smoke would be a certain indicator of an overhaul. White smoke is usually water vapor and could mean a broken/cracked head or a bad head gasket. If you have antifreeze in that tractor and the exhaust has a sweet smell to it, you're burning antifreeze.
misfiring cylinders can cause white smoke which is really unburnt fuel.. why don't you fix the choke control,each time it's out the air is being restricted.check leads and plugs .
Fix the choke by putting a weak spring on the rod pulling it to the no choke position. Every SH with a properly operating carb needs the choke for about 15 seconds (on a very cold day). There is a tiny spring and ball in the carb body at the choke shaft that is missing, or rusted/worn out. It holds the choke open when working correctly.
If the smoke is usually when at idle, or going down a hill with the throttle shut, it could be from the valve guides. I would throw a set of umbrella or PC style valve stem seals on it to see if it is better. If it is loosing coolant, that is the real answer, and needs further investigation. The valve seals can be installed without removing the head. JimN
