Anonymous-0
Her brother has a 1969 565 converted to propane, that he needs to sell. I dont know what something like this is worth, its in ok shape, running, 3piont, bucket and hydrualics work good. It doesnt want to shift over into 3-4, it only goes 1- rev. high and low. I would like to buy this tractor and fix it up, he said he paid 7000.00. It didnt have the shifting problem then. Can anyone help me out
Shifting problems are common Clean up every pivot, link end and bushing. Make sure the clutch is adjusted correctly, and she will be fine. Value from a "her brother" is always an issue for the family. Jim
thank i will try cleaning it today. I purchased it yesterday for 3500.00. The only other question is propane or gas, which is better. It does run good on propane so leave it a lone???
I would leave it alone, the Propane is a bit of a hassle filling, but it provides a great fuel. Some shifter tips are replacing bushings with longer ones that have more bearing ares, using non stock rod ends from motion industries for replacing worn components, shifting carefully and with the clutch fully depressed. JimN
