Feeding moldy corn
I have some corn that is still standing that I didn't combine last fall because it was planted very late and didn't mature. I chopped some of it last fall with a green chopper and feed it to beef cows. I was thinking of doing that again this spring before I chop it to the ground and then plow it under. I looked at it yesterday and I noticed a little mold on it. Can I still chop it and feed it to the beef cows as A way to stretch my hay?????? Let me know what you guys think.
Joe
i had a bunch of sweet feed that got moldy...i put it on the trailer to move down to the pond to give it to fish...got side tracked and cows got into it...they cleaned the trailer off and all still healthy...your mileage may vary.
We used to mix it with hay and other grain, run it thru the grinder/mixer and feed it. Didn't lose any pounds or head. But, as as is said, your miles may vary.
It's hard on pregnent stock.
Basically that's how they use the stuff, blend it off with good stuff until the mold level is low enough not to be a problem.
The difficulty is in 'guessing' at that proper level.....
Is it a grey green surface mold you can wipe off with your hand mostly, that one isn't any problem at all.
Is it a green mold in the kernal, or a reddish mold in & on the ends of the ear kernals, or which? Different kinds have different levels of threat.
--->Paul
Check with your feed dealer to determine who can analyze samples. Some molds are toxic, others not. Growing animals can handle mold better than pregnant ones. A lot of mold was knocked off by combines last fall, maybe your chopper will do the same.
