Fence charger
BO NW/MS
This is a great site. I have enjoyed it for years
I need some help. I have a Zareba SP 10 solar fence charger that slowed, the light dimmed and it stopped working. I only need it for a few days until I can replace a fence. I don't want to buy a battery. could I use a 6v flashlight or a 12v auto battery? any other battery could I use?
I have used a 12v auto battery on a 6v charger and it worked find. thanks BO
you can use the same voltage as battery in charger now safely...i wouldnt reccomend a flashlight battery...they just dont have the oooomph a wet cell or gell battery have.
pull the battery and hook it to a car charger for a while...mine was doing the same thing, apparently it wasn't getting enough sun to fully charge the battery. also, check for ground faults to make sure it's not discharging that way as well.
I'd bet on a ground problem (fence shorting somewhere)... Unhook it from the fence and try it. I just about went bald today with a charger/battery that I knew was good and the needle wasn't moving. Turned out a cracked insulator let it ground. Couldn't see it and searched the whole fence several times. Went back to the house and got my Gallagher Smart Fix (best thing since sliced bread) and found it right away.
Good Luck,
Dave
