Hello,
Someone in the past has put a small pump between the gas tank and carb with rubber line. In the manual I do not see this as a factory part. So I'm trying to get it back the way it originally was.
The parts book shows only a gas line between the sediment bowl and carb but I'm not finding this anywhere. If carb is fed only by gravity then I want to remove the pump. So what size line do I need? or what is my options?
Serial number: 162807
Any help would be greatly appreciated
thank you
thank you
