ferguson 35 deluxe
ohiojim
Location
Tn
anyone know about this tractor, was told it had english deisel motor , not perkins,..are they good engines, are parts hard to find as it needs work,...seems overall good shape just a lot of neglect...
yes,its has what is called a STANDARD english diesel motor.overhualed one about four years ago.found a parts suppplier in canada
The Delux tells you it has the two stage clutch and a tractor meter. That is all. You have to look at the engine to decide if it is a Gas, Standard Diesel or Perkins Diesel.
If the serial data plate has a three letter code then that will also help to Identify it.
1st letter likely "S" = Standard Chassis
2nd letter
"G" = Gasoline
"N" = Diesal - Standard
"D" = Direct injection Diesal
3rd letter is the clutch type
"M" = two stage
